Valg af receiver! Valg af receiver!
Hej Alle, jeg har den sidste mdr tid kigget efter ny receiver, da min Jamo AVR-793 ikke virker mere! Jeg kan ikke vælge mellem disse Pioneer SC-2022 og Denon 2313, mine højtaler er
---------- E 770 "FRONT" ----------
System 3 Way Bassreflex
Woofer (inch/mm) 6½ / 165
Midrange (inch/mm) 6½/165
Tweeter (inch/mm) 1
Sensitivity (dB - 2,8V / 1m) 90
Impedance (Ohm) 6
Weight (kg/lb) 17,2/37,92
Dimensions (HxWxD/mm/in) 998x195x320/39,29x7,68x12,6
Frequency Range 35 - 20.000
powerLongTerm 150
powerShortTerm 220
terminalType Gold plated screw terminals
totalVolume 62,3/2,2
---------- E700 " BAG SURROUND" ----------
system 2 Way Bassreflex
Woofer (inch/mm) 4 / 102
Tweeter (inch/mm) 1
Sensitivity (dB - 2,8V / 1m) 85
Impedance (Ohm) 6
Weight (kg/lb) 3/6,61
Dimensions (HxWxD/mm/in) 238x140x165/9,37x5,51x6,5
Frequency Range 70 - 20.000
powerLongTerm 100
powerShortTerm 140
totalVolume 9,3/,33
---------- E 7CEN "Center" ----------
Woofer (inch/mm) 2 x 4 / 102
Tweeter (inch/mm) 1
Sensitivity (dB - 2,8V / 1m) 87
Impedance (Ohm) 6
Weight (kg/lb) 5,8/12,79
Dimensions (HxWxD/mm/in) 142x440x170/5,59x17,32x6,69
Frequency Range 100 - 20.000
powerLongTerm 100
powerShortTerm 140
totalVolume 10,6/,37
--------- SUBWOOFER ----------
system Closed Cabinet
Woofer (inch/mm) 12 / 305
Impedance (Ohm) 22k
Weight (kg/lb) 22.2 / 48.9
Dimensions (HxWxD/mm/in) 419x400x418 / 16.5x15.7x16.5
limiter limiter
Amplifier Rated Output 650
Frequency Range 24-150
cut Off Frequency 40-150
phase Variable
feb 2011
Har du mulighed for at låne ?
aug 2012
Følger: 2 Følgere: 1 AV-enheder: 1 Emner: 4 Svar: 16
feb 2010
http://www.redcoon.de/B373995-Onkyo-TX-NR818-Schwarz_7-Kanal-AV-Receiver?refId=psm
Valg af receiver!
